1999 Chevy Monte Carlo oil smells like gas
150,000 MILES • 6 CYL • FWD • AUTOMATIC
BELLFROMHELL
I noticed when i checked my oil that it smells like gas. I also smell gas when I start it. I also have the check engine light on . I checked the code on the code reader and it says multiple cylinder misfire. I did have a leak in the fuel rail and fixed it. But it still smells like gas in the oil.
Nov 4, 2010 at 11:00 AM
HMAC300
  • 48,601 POSTS
i fyou have a code and didn't fix it it is dumping fuel in yoru engine. fix the problem and change your oili and filter.. Multiple misfirescan be spark plugs, wires, fuel filter or injector problem......
Nov 6, 2010 at 1:55 AM
