1999 Chevy Monte Carlo MAP Sensor
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
FORKFEET
1999 Monte Carlo Z34, 3800 MAP Sensor. I cannot get the 2 "funky" screws out that hold it on. They look like "STARS" but when I try to use a "star", it will not fit because there is something in the CENTER of the star. In the middle if you will, that prevents the bit from seating into the head of the bolt. Is this some special bit I will need to buy, or am I missing something? Thanks
Apr 21, 2009 at 11:04 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You will need a special bit that looks similar to the examples below..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_467.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_2_36.jpg
Thanks for using 2CarPros.com!
Apr 21, 2009 at 11:09 AM
