1999 Chevy Monte Carlo gas cap replacement
46,000 MILES • 6 CYL • FWD • AUTOMATIC
FLACO1
how do I remove original gas cap and replace it with a locking gas cap?
May 15, 2008 at 10:22 AM
RHALL77
  • 3,361 POSTS
you should be able to cu the teather and remove it. make sure the locking gas cap is approved for the car otherwise you will be setting check engine light all the time for emission codes.
May 16, 2008 at 2:18 AM
