1999 Chevy Monte Carlo antifreeze
181,356 MILES • 6 CYL • FWD • AUTOMATIC
BGSHIPLEY
after driving the car can smell anti freeze burning can't find a leak have replaced the water pump all the hoses even the one from holding tank to radiator can fill the holding tank and 4 days later have to fill it again, 2 years ago replaced the lower intake gasket and thermastat
Oct 14, 2010 at 12:04 AM
WRENCHTECH
  • 20,760 POSTS
You have an obvious leak. You just haven't found it yet. You need to pressure test the cooling system and the leak will eventually show up.
Oct 14, 2010 at 12:18 AM
