1999 Chevy Monte Carlo
HOU1AXT
1999 Chevy Monte Carlo 6 cyl Automatic 154000 miles
1999 Monte Carlo, automatic. Test scan show code P0753 , 1-2 Shift Solenoid circuit failure 1-2 failure. What do I need to check first to find the problem
Nov 3, 2009 at 3:39 AM
HMAC300
  • 48,601 POSTS
take it to a trans shop as there may be other problems causing this. The shift valves are in the trans anyhow. As long as it gets power to it then it's an internal problem.
Nov 4, 2009 at 4:19 AM
