1998 monte carlo
FINESS_CARTEZ
I have a 98 monte carlo 3.8 litre engine with 125,000 miles and i just had the engine replaced the problem that my car is having is it wont shift out of second gear and also the speedometer is not giving a reading..i wanna know can these problems be related and a possible solution to both
Nov 13, 2007 at 7:09 AM
DENNYP
  • 1,824 POSTS
make sure the speed sensor on the transmission is plugged in.
Nov 13, 2007 at 11:08 AM
FINESS_CARTEZ
where is the speed sensor located on the transmission and will that cause the gears to not shift properly if its not plugged in or are those separate problems
Nov 14, 2007 at 12:54 AM
