1998 Chevy Monte Carlo wipers
1998 CHEVROLET MONTE CARLO
129,000 MILES • 6 CYL • FWD • AUTOMATIC
PRETTYLADY1375
my wipers go up only a few inches and seem like they are stuck, the motor is working the hole time this is going on and also they only work on high when they do work but for 2 days now they will only go up about 2 inches. they go up and down continuously they dont actually stop moving they just wont go up all the way. im wondering if it may b the switch in side the car that u use to turn them on or should i be looking at something else. if it is the switch in the car is that really hard to change out you self. please help
Mar 6, 2009 at 8:14 AM
  • 110,240 POSTS
It sounds like a linkage problem. The linkage is under the cowl at the base of the windshield. Remove the cowl and see if the linkage is damaged. Also, make sure the wiper arms are tight onto the mount.
May 13, 2009 at 1:42 PM
