1998 Chevy Monte Carlo P0440
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
BROWNP
I have a 98 Monte Carlo with trouble code "evaporation systems failure." The gastank leaks at the seam when its filled above a 1/2tank. Could the tank cause this code or is it likely to be somthing else?
thanks.
Feb 17, 2010 at 12:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if the fuel tank has a leak in it then yes it will definitely throw this trouble code.
Feb 17, 2010 at 1:08 PM
