1998 Chevy Monte Carlo id of problem
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
DGUNDER
1998 monte carlo temperature guage shows car is overheating in red. acceleration is lost and will not go faster than 30-40. cooling fans work motor blows out cool air when heat turned on. no leakage noted
Apr 27, 2008 at 8:32 AM
  • 75,988 POSTS
Get the cooling system block and pressure tested and also check for excessive backpressure in the exhaust and throttle position sensor.
Apr 27, 2008 at 8:46 AM
