1998 Chevy Monte Carlo heater control valve
1998 CHEVROLET MONTE CARLO
KAHAINUI415
Heater problem
1998 Chevy Monte Carlo Front Wheel Drive Automatic
where is the location of the heater control valve on a 1998 monte carlo
Feb 26, 2010 at 2:27 PM
DOCFIXIT
  • 18,828 POSTS
Does not have one what's the problem?
Feb 28, 2010 at 6:23 AM
KAHAINUI415
heater control valve was suggested by another site. I changed thermostat because i seen antifreeze leak there, replaced lost antifreeze, still no heat. No visual leak from heater core.
Feb 28, 2010 at 11:19 AM
DOCFIXIT
  • 18,828 POSTS
Most likely blend door actuator should be able to get at by removing glove box. it is an electric motor see if it moves by changing Temp for cold to hot.
Mar 1, 2010 at 3:04 AM
