HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Monte Carlo
Engine
Symptoms
Overheat
SPONSORED LINKS
1998 Chevy Monte Carlo
MARYWORRICK
MEMBER
1998 CHEVROLET MONTE CARLO
Engine Cooling problem
1998 Chevy Monte Carlo 6 cyl Two Wheel Drive Automatic
I need intake torque specs with a diagram please
Sunday, February 21st, 2010 AT 4:40 PM
DOCFIXIT
MECHANIC
Upper or lower and 3.1L or 3.8L?
SPONSORED LINKS
Monday, February 22nd, 2010 AT 3:36 PM
MARYWORRICK
MEMBER
Upper please on 3.1 engine
Monday, February 22nd, 2010 AT 11:21 PM
DOCFIXIT
MECHANIC
On 3.1 GM does not provide a sequence they say use crisscross method. So start in center in an X pattern tighten to 18 ft. Lbs.
Tuesday, February 23rd, 2010 AT 9:00 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1998 Chevrolet Monte Carlo Over Heating
Changed Water Pump And Thermostat. Still Over Heating And Heater Not Producing Heat And Radiator Not Holding Fluid's And Reservoir Not...
Asked by
leigh72
1 ANSWER
1998
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
Engine Overheating
My 2005 Monte Carlo (3.4 V6) Says Hot Coolant Temp, Temp Guage Goes Into Red But Blows Out Cold Air Through The Heater Vents. It Seems To...
Asked by
kahuffman8784
2 IMAGES
2005
Overheating
Have Replaced The Water Pump Put 2 Different Thermostats In It The One In It Now Is A 160 Degree Thermostat And Hooked Up The Fans Direct...
Asked by
timmytrulock
1997
Monte Carlo Overheating
My Son Has A 1999 Monte Carlo. It Overheats And Also Heater Isnt Blowing Warm Air. The Radiator Fluid Keeps Going Into The Overflow Tank And...
Asked by
pattisw
97 Monte Carlo 3.1 Overheating
My Car Is Overheating It Goes From Cold To Hot In 5 Minutes All Of My Antifreeze Is Going Into My Overflow Reserve And My Radiator Cap Is...
Asked by
BsMonte
1997
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test For Leaks
Online car repair manuals
