HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Monte Carlo
Engine
Cylinder Head
Gasket
Replace/Remove
SPONSORED LINKS
1998 Chevy Monte Carlo
TODD HAMM SR
MEMBER
1998 CHEVROLET MONTE CARLO
6 CYL
FWD
AUTOMATIC
169,550 MILES
I just changed the head gaskets on my 98 monte carlo and now it is running rough and sometimes backfires what could cause this
Thursday, January 7th, 2010 AT 1:16 PM
SCOTTY DEE
MECHANIC
Is the rocker arm tension adequate? Is the firing order correct? Any issues noticed with the valve when the heads were off? Broken valve springs?
SPONSORED LINKS
Tuesday, January 26th, 2010 AT 8:45 PM
SCOTTY DEE
MECHANIC
Is the rocker arm tension adequate? Is the firing order correct? Any issues noticed with the valves when the heads were off? Broken valve springs?
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Replace/Remove Content
When Changing The Head Gasket On The 3.4 Dohc Can I...
When Changing The Head Gasket On The 3.4 Dohc Can I Pull Both Heads With Out Pulling The Motor Out Of The Car?
Asked by
Anonymous
1 ANSWER
2 IMAGES
1996
Head Gasket Replacement Needed In The Near Future
Head Gasket Kit Doesn't Include The Head Bolts Or Exhaust Pipe Packing That May Possibly Required & Needed To Complete The Head Gasket...
Asked by
sara7373
1 ANSWER
1996
2002 Chevrolet Monte Carlo Electrical
Ok So I Am Working On A 2002 Monte Carlo With The 3.4 3400 Engine I Changed The Head Gaskets Manifold Gaskets Everything Put It All Together...
Asked by
matt66693
2002
1995 Chevy Monte Carlo
What Does It Cost To Replace A Head Gasket? And Can You Do It Yourself Without Taking It In To A Mechanic?
Asked by
Nicole19
1 ANSWER
1995
2004 Chevy Monte Carlo Head Gasket
I Recently Replaced My Waterpump And I Was Wondering If This Means I Will Have To Replace My Head Gaskets Also.
Asked by
mrspaulette
1 ANSWER
2004
VIEW MORE
SPONSORED LINKS
Coolant Mixing With Engine Oil
Topdon OBD2 Scanner Review - This thing rocks
Engine Oil Change and Filter Ford Mustang
Online car repair manuals
