1997 Chevy Monte Carlo turn signal relay
160,000 MILES • 6 CYL • FWD • AUTOMATIC
AICFANLLMIII
My turn signals on my 1997 monte carlo do not work. My emergency flasers still work, cruise control, and wipers still work. I have changed fuses but don't know where the flaser relays are located so i can check and change them. Thanks for the help
Mar 14, 2008 at 10:12 AM
CROCK5677
  • 7 POSTS
The relay is located on the left side behind the emergency brake under the dash.Turn your flashers on and you can trace the clicking to the square black box. It sounds like the turn signal switch itself is bad,not the relay.
May 19, 2008 at 1:05 AM
