Hi- I had to replace T-stat recently. It was unbelievably hard. If you haven't already done it, my amateur car repair tips are as follows:
You have to remove entire air filter unit, don't try to push it aside. it's gotta come out
You have to remove the Throttle body Unit, I mean undo bolts holding it to Upper Intake Manifold and put it to the side
When you do these things along with other basic removal of upper Radiator hose etc, yoiu will then be able to get to T-stat bolts. They require 13mm socket for upper bolt, and 13mm open end wrench for lower bolt. GOOD LUCK
Aug 12, 2019 at 12:13 PM
(Merged)
