1997 Chevy Monte Carlo running hot
STEVENSCAR
Engine Cooling problem
1997 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic
my 97 monte carlo overheats just a few minutes after its started... all the way to hot. ive replaced the thermostate , the coolant, cheacked the hoses, waterpump, and radiator, theres no water in the oil.but steming some out of the exsaust, please help
Aug 26, 2008 at 8:13 AM
  • 75,988 POSTS
Get it checked for a blown headgasket cracked head or block-have the tests below done.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: ,Pressure test the Rad. cap,Clogged radiator,air lock in the cooling system ,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Aug 26, 2008 at 8:29 AM
