1997 Chevy Monte Carlo pressure release on rear calipers
VICKDUNNIT007
Brakes problem
1997 Chevy Monte Carlo 4 cyl Front Wheel Drive Automatic
how do you realese pressure on rear brake calipers on a 97 chevy monte carlo.....
Nov 1, 2009 at 8:21 AM
  • 110,248 POSTS
There could be one of two problems. The piston could be stuck or the rubber brake hose going to it is bad. Is it only one side you are having trouble with? If so, try this. Loosten the bleeder valve on the caliper to see if that will allow the piston to depress. Let me know what you find.
Nov 18, 2009 at 12:11 AM
