1997 Chevy Monte Carlo LOW COOLANT LIGHT ON
1997 CHEVROLET MONTE CARLO
131,000 MILES • 6 CYL • FWD • AUTOMATIC
CHARLESTNBLUE
MY LOW COOLANT LIGHT IS ON, BUT MY RADIATOR AND THE RESEVOIR IS FULL OF COOLANT I JUST RECENTLY HAD MY HEADS REPLACED IS IT SAFE TO DRIVE WITH THE LIGHT ON?
Mar 12, 2008 at 10:46 AM
CYDNEYWI
Hi. I have a 95 Monte Carlo with the same problem. My daughter has the identical car, also with the same problem. Did you ever get an answer? I went on AutoZone.com and found a sensor that might need to be replaced. Thanks Cydneywi
May 2, 2008 at 9:49 AM
