1997 Chevy Monte Carlo Intake gasket
1997 CHEVROLET MONTE CARLO
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
LUCINDA22
Can a leaking intake gasket cause the car to over heat?
Aug 17, 2010 at 11:48 AM
WRENCHTECH
  • CERTIFIED EXPERT
  • 20,761 POSTS
It certainly can. In fact it's quite common on that vehicle. The intake gaskets leak coolant at the coolant ports and when it has lost enough it will overheat.
You want o be real care with that too. It can also leak into the engine and into the crankcase which can cost you a motor.
Aug 17, 2010 at 11:55 AM
