1997 Chevy Monte Carlo Engine heats when idleing
1997 CHEVROLET MONTE CARLO
149,000 MILES • 6 CYL • 2WD • AUTOMATIC
LITTLEOTTERINGA
I blew the top radiator hose and replaced it. Now as I drive temp is fine unless I get caught in long stops
( 3 turns before I get through a light) I checked the fan fuse it's ok. But there are 2 large fan fuses Could this be the problem? If not what is? thanks
Mar 29, 2008 at 11:37 AM
Yup! could be the 2 fan relays that's causing it or an engine coolant temperature sensor or switch
Themostat is it in perfect condition?
Mar 29, 2008 at 11:50 AM
