1997 Chevy Monte Carlo Brake Lights
GODSCHILD08
Brakes problem
1997 Chevy Monte Carlo V8 Wheel Drive Type unknown Automatic 102000 miles
When stopping my brake lights come on, but soon cut off. I have change the bulbs, the fuse and I am still having the problem. Help!
Feb 18, 2008 at 8:37 AM
2CARPRO JACK
  • 11,533 POSTS
Test the white wire for power while holding brake pedal down. If it goes away, replace the brake light switch.If it stays then do the same test to the dark green wire out of the turn signal switch, if it fails, replace the TSS
Feb 18, 2008 at 10:54 AM
