1997 Chevy Monte Carlo
114,000 MILES • 6 CYL • FWD • AUTOMATIC
JCLB1985
I went out to start my car this morning and it started up fine. I turned the defrosters on and after a few minutes, I noticed that there wasn't any warm air coming out. I didn't think anything of it because the heat is usually slow but it's never been this bad. While I was driving, the thermostat in my car kept fluctuating between hot and cold. The heat seems to work fine when I'm accelerating but when I have to slow down, it starts blowing out cold air and the thermostat reflects it by getting warmer. But then when I accelerate again, the heat works and the thermostat goes back down to normal. I'm not much of a car guy and I was wondering what I could do about getting it repaired?
Dec 17, 2007 at 10:06 PM
JRMASON
hey guy that sounds like you need to replace your thermistat that could be one reason if not you need to check to see do you have antifreeze in there
Feb 10, 2008 at 11:44 AM
