1996 Chevy Monte Carlo slight slip in 1st gear
185,000 MILES • 6 CYL • FWD • AUTOMATIC
FLOWJOE42069
my car is at firestone had some test done for hesitation in exceleration test found that fuel filter fuel pump and a fuel line are bad plus a slight slip in 1st gear before i call firestone back to fix filter and pump i want to find out cheap options for fixing 1st gear tranny slip
Feb 9, 2010 at 7:46 AM
  • 110,248 POSTS
There may not be a cheap fix. Is the ATF full? Is the fluid clean? If so, chances are the clutch plates are going bad and will need replaced.
Feb 15, 2010 at 5:35 AM
