1996 Chevy Monte Carlo Fan Speed
1996 CHEVROLET MONTE CARLO
12,300 MILES • 4 CYL • 2WD • AUTOMATIC
TOM HONTZ
When I accelarate the AC fan slows drastacally,letting little to no air flow
Apr 15, 2010 at 9:30 AM
MERLIN2021
  • 17,250 POSTS
Are you sure it's the fan speed or is it the air changing to defrost registers?
Aug 16, 2018 at 11:01 AM
TOM HONTZ
[quote:29a9dd8c0d="merlin2021"]Are you sure it's the fan speed or is it the air changing to defrost registers?[/quote:29a9dd8c0d]
It is definitely fan speed loss of flow each time I accelarate.
MERLIN2021
  • 17,250 POSTS
You could check the blower motor resistor, it's mounted under the dash on the passenger side, attached to the heater plenum next to the blower. Is anything else affected? Lights get brighter or dimmer? Radio? etc...
