Monte Carlo starts without any problems, after running about ten minuets it idles very rough and the RPM drops and it stalls. If I restart it and keep it running by pumping the accelerator it may run a while longer then if stalls it will crank but will not start.
After it sits for about one half hour it will start again and go through the same as above.
Aug 31, 2009 at 11:01 AM
