1996 Chevy Monte Carlo cooling fans
HARVICK29
Engine Cooling problem
1996 Chevy Monte Carlo 6 cyl Two Wheel Drive Automatic
replaced the enginebecause thetiming beltbroke replaced all the gaskets but the heads new sensors even the ect the cooling fan only works sometime a/c fan doesnt workat all a/c compressor doesnt work at all but did was blowing the air pumpfuse tested the relays works dont know what else to look for. Any help wouldbe appreciated.
Jan 21, 2010 at 1:30 AM
SCOTTY DEE
  • 592 POSTS
You need to get a wiring diagram and verify that all the connections are proper after the engine R&R. The cooling fans should come on around 190 degrees, and the A/C fan comes on only when the AC is on and running. So at 190 and above, AC on, both fans should be running.
Jan 26, 2010 at 10:59 AM
