1996 Chevy Monte Carlo 1996 monte carlo will turn but not s
148,263 MILES • 6 CYL • FWD • AUTOMATIC
MICH4EVA23
I have a 1996 Chevy Monte Carlo that I’m trying to get running. I recently took it to an auto shop and they could not get it running. They checked the Timing chain, fuel pressure, ignition module, coils; engine compression was good, added new fuel, fixed some wiring but could not get it to start. The engine will turn, its getting spark but will not catch and start up. The batter is new. Do you think that you can help me out?
Sep 23, 2010 at 8:43 AM
  • 75,988 POSTS
Hi Mich4eva23, Welcome to 2carpros and TY for the donation
Start by checking the fuel pressure if its within specs if okay verify the valve and ignition timing and then get back with me-
Sep 23, 2010 at 9:30 AM
MICH4EVA23
The fuel pressure is good. the ignition is good. Also 'no' check engine light is on.
Sep 23, 2010 at 2:23 PM
  • 75,988 POSTS
Fuel and ignition system are good-check the valve and ignition timing
BTW fuel pressure is good but are the injectors pulsing providing fuel to the cylinders
Sep 23, 2010 at 2:28 PM
