1996 Chevy Monte Carlo
STEVEEIN78
  • 1996 CHEVROLET MONTE CARLO
  • 6 CYL
  • 150,000 MILES
My sons 96 monte carlo almost always started immedilately.2 weeks ago started having problems starting. Would just seem to take longer to start. He borrowed a friends car for about a week. I went down to see him, got in the car and it started right up. Drove it for 10 min. Stopped and got gas. Went to start it and would barely turn over for 1 to 2 seconds then it started. Drove to auto parts store shut it off. Same thing happened when I started it again. They checked battery and alternator and they checked fine.
Tuesday, October 19th, 2010 AT 12:59 PM
WRENCHTECH
  • 20,761 POSTS
The next thing to test would be the starter current draw while the engine is hot.
Tuesday, October 19th, 2010 AT 1:08 PM
STEVEEIN78
They checked starter while they were checking battery &alternator and it checked ok but they said a true test would be to take starter off and bench test it. Would this be the next thing to do?
Tuesday, October 19th, 2010 AT 1:37 PM
WRENCHTECH
  • 20,761 POSTS
No, that is completely wrong. You can't test current draw when it's off the car. It has to be done in the car and only when the engine is hot. They have to measure amp draw not voltage drop.
Tuesday, October 19th, 2010 AT 1:39 PM
STEVEEIN78
Can this be done at auto zone or similar type parts store?If not where is your suggestion to take it to?
Tuesday, October 19th, 2010 AT 2:08 PM
WRENCHTECH
  • 20,761 POSTS
Not likely. All they use is a simple voltage drop test. You need to measure the amp draw of the starter when the engine is hot because that will be when it at it's worst.
Tuesday, October 19th, 2010 AT 2:46 PM
