1996 Chevy Monte Carlo
MRSDJPS
1996 Chevy Monte Carlo 6 cyl Two Wheel Drive Automatic
My 1996 Monte Carlo is having a problem. Car would only idle. Would not move. Changed fuel filter. This seemed to help. Pressure test on fuel pump showed low. Could it be pulsator. Moves now after changing filter.
Sep 27, 2008 at 11:37 PM
MERLIN2021
  • 17,250 POSTS
If you pessure tested the pump and the prssure was low, recheck it this way, if the regulator is bad change that, if the pressure does not rise during this test replace the pump, it's in your tank! Test equip, can be found here, if needed.
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
You can rent the test gauge.
Sep 27, 2008 at 11:54 PM
