1995 Monte Carlo
JTMORGAN
The sound that goes off when the car door is open will not shut off. It is draining the battery. How can I disable it.
Feb 2, 2007 at 10:20 AM
SERVICE WRITER
  • 9,123 POSTS
You can't disable it as I see it. Teh electrinic brake control module is on that circuit, so you can't pull the fuse, and if you pull the chime module, you lose the trun signals. There is a problem with a ground or door jamb swtich I believe.
https://images.2carpros.com/forum/automotive_pictures/30961_chime_1.jpg
Feb 2, 2007 at 10:38 AM
