1995 Chevy Monte Carlo vacuum leak
AHENKE
Engine Performance problem
1995 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic
I have a vacuum leak where the hose from the pcv valve plugs into the back of the throttle body it looks like a piece is missing because the hose is just laying over the hole and is leaking air causing a high idle about 1500rpm
Nov 7, 2009 at 2:56 AM
  • 110,248 POSTS
The hose needs replaced. The old one will pull off and a new one will slip back on.
Nov 18, 2009 at 12:03 AM
