Engine Performance problem
1995 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic
I have a vacuum leak where the hose from the pcv valve plugs into the back of the throttle body it looks like a piece is missing because the hose is just laying over the hole and is leaking air causing a high idle about 1500rpm
Nov 7, 2009 at 2:56 AM
