1995 Chevy Monte Carlo Rough Idle
1995 CHEVROLET MONTE CARLO
ZACHMM07
Engine Performance problem
1995 Chevy Monte Carlo Front Wheel Drive Automatic 76000 miles
when the car is cool and I start it It will idle up to 2000-2500rpm and immediately drop to 1000rpm, if I dont give it gas It will stall.
May 27, 2008 at 2:55 PM
LEGITIMATE007
  • 5,121 POSTS
check your throttle position sensor along with your idle air control valve , both of these sensors will give you the symptoms that you are describing.
May 27, 2008 at 5:23 PM
