1995 Chevy Monte Carlo no power
DELGATO
i was recently in a minor accident where i rear ended someone but ever since when i drive the car in drive or overdrive theres no power i mean i can put the accelorator to the floor and it still takes alot of time to build speed what is the problem?
Jun 21, 2009 at 8:40 AM
BUDDYCRAIGG
  • 2,262 POSTS
Does the engine sound normal? or have a check engine light?
Next time you finish with a long drive, touch the metal part of both of your front wheels around where the lug nuts go.
Be careful , they may be very hot.
They should only be warm but if one or both are too hot to touch, you may have damaged a brake line or hose when you had your accident.
And the fluid pressure is keeping your calipers clamped on the rotors, Like if you were driving with your foot on the brake pedal.
good luck
Jun 21, 2009 at 8:56 AM
