Heater will heat up if idle and not below freezing outside. Once it heats up when I start driving the heat turns cold. When I stop or park it warms up again. Heat pretty much works fine if not too cold outside. 40degrees and above works fine. Below that won't heat when driving.
Jan 31, 2008 at 12:32 AM
