HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Monte Carlo
Engine
Symptoms
Overheat
SPONSORED LINKS
1995 Chevy Monte Carlo cooling trouble
95MONTE
MEMBER
1995 CHEVROLET MONTE CARLO
6 CYL
FWD
AUTOMATIC
120,000 MILES
My engine runs hotter than I think it should the fans dont kick on until it is almost over heating, where could I start looking?
Friday, May 30th, 2008 AT 9:34 PM
MECHANIC
Hi there,
Replace the thermostat and have the radiator flushed & flow tested. Do this first.
Mark (mhpautos)
SPONSORED LINKS
Friday, May 30th, 2008 AT 9:40 PM
95MONTE
MEMBER
Thanks will do that first thing thanks again
Friday, May 30th, 2008 AT 9:46 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1995 Chevy Monte Carlo Problems With Over Heating
1995 Chevy Monte Carlo Automatic Before Starting My Car This Morning, I Checked The Fluids, Refilled The Coolant And Such...
Asked by
Miahchild
1 ANSWER
1995
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1995 Chevy Monte Carlo Problem With My Heat
Engine Cooling Problem 1995 Chevy Monte Carlo 6 Cyl Front Wheel Drive Automatic My Car Tries To Over Heat. Theres Antifreeze In It. It...
Asked by
plevasseur
1 ANSWER
1995
Engine Overheating
My 2005 Monte Carlo (3.4 V6) Says Hot Coolant Temp, Temp Guage Goes Into Red But Blows Out Cold Air Through The Heater Vents. It Seems To...
Asked by
kahuffman8784
2 IMAGES
2005
Overheating
Have Replaced The Water Pump Put 2 Different Thermostats In It The One In It Now Is A 160 Degree Thermostat And Hooked Up The Fans Direct...
Asked by
timmytrulock
1997
Monte Carlo Overheating
My Son Has A 1999 Monte Carlo. It Overheats And Also Heater Isnt Blowing Warm Air. The Radiator Fluid Keeps Going Into The Overflow Tank And...
Asked by
pattisw
VIEW MORE
SPONSORED LINKS
Coolant Leak Symptoms
Online car repair manuals
