Here is the story. Started getting coolant leakage under the hood and it was all pooring from the area of the water pump. Had the water pump replaced, then after I got it back from the mechanic it started to overheat, which it didnt do before I took it in. So then I noticed it was spraying from the radiator cap and was spraying up and over towards the water pump. So likely it wasnt even the water pump to start with. So now I have replaced the radiator cap, didnt help. Replaced the temprature sensor, fan relay and still nothing. Note the whole time the fan wouldnt engage. So now I hard wired the fan to a toggle switch and it still does not cool it. Still says its over heating. Someone said maybe the temp gage is not working so now I dont know what else to do other than replace the radiator. Any suggestions?
Feb 10, 2009 at 9:09 AM
