1995 Chevy Monte Carlo cooling fans
174,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHN BOY1969
my cooling fans on my monte carlo dont work i jumped the relay over and the fans run the relays are good what ealse should i do
Apr 27, 2009 at 4:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty engine coolant temperature sensor. If fan motor is indeed working when jumping new relay then ECT sensor must not be sending proper signal telling fans to come on.
Thanks for using 2CarPros.com!
Apr 27, 2009 at 5:04 PM
