1995 Chevy Monte Carlo Code 51 ECM Prom error
149,000 MILES • 6 CYL • 2WD • AUTOMATIC
VANILLACREAMF40
Error 51 ECM prom error came up in a diagnostic test. I was told this is only a dealer part and can be very expensive. I want to know if I can find another car like mine and take this part and install it in my car, I believe I would have to take the entire brain? Where is this "brain box" located and how much time is involved in replacing it?
Jul 9, 2008 at 6:59 PM
RHALL77
  • 3,361 POSTS
as long as you replace it with a used part, make sure everything is the same part number and service number
Jul 10, 2008 at 12:48 AM
VANILLACREAMF40
[quote:7492632ebc="rhall77"]as long as you replace it with a used part, make sure everything is the same part number and service number[/quote:7492632ebc]
Thank you for your advise but I also needed to know where the ecm prom is located, "brain box"?
Jul 12, 2008 at 12:44 PM
