15 amp fuel injector fuse keeps blowing as soon as the key is turned on
Dec 24, 2007 at 6:30 AM
MERLIN2021
✓Experienced Mechanic
Use an ohm meter and check the resistance at all injectors, If you unplug the injector harness doe the fuse still blow? 3.4 resistance should be 11.8-12.6 ohm at 60 degrees...
Dec 24, 2007 at 6:33 AM
