1987 Chevy Monte Carlo seat belt driver side
JAMES R.COX
Interior problem
1987 Chevy Monte Carlo V8 Two Wheel Drive 89000 miles
the seat belt rewind has come detached from the side wall of body,it will not rewind or pullout---there is a metal bracket on the top to fit imto a T SLOT,amd a location for a bolt at the bottom,,however there is no room for the rounded back of the recoil unit to fit into the sheet metal panel....also the pass.side rewind has a leaver door operated rod that operates a latching mech.. the driver side does not ,,,aney help appreciated james cox
Jul 26, 2009 at 12:05 PM
2CARPRO JACK
  • 11,533 POSTS
Any chance of getting apic of what you are talking about? If I remember correctly the retractor bolts in at the bottom and the top is simply a pivot for the shoulder belt
Jul 27, 2009 at 6:56 AM
JAMES R.COX
i have no way to send pictures on line
also how do i send cash on line,as i see no other way to pay????
Jul 27, 2009 at 11:30 AM
2CARPRO JACK
  • 11,533 POSTS
you can contact mike@2carpros.com for payment info. Are we on the right track with the seat belt as far as the retractor being down low?
Jul 27, 2009 at 5:36 PM
JAMES R.COX
thanks for the help but i needed this fixed this week
time has run out,,i give up
Jul 30, 2009 at 1:18 PM
