1986 Chevy Monte Carlo slow take off
1986 CHEVROLET MONTE CARLO
56,000 MILES • V8 • 2WD • AUTOMATIC
WILLIEBESS
when i take off from a stop sign, or stop light and i hit tha gas hard, instead of it taking off like its suppose to do it kinda stalls for a second and then picks up speed. i would think if i hit the gas real hard with the new carburetor i bought, i would think that the tires will burn out a lil, but instead it stalls then picks up speed. people tell me that its the timing is off. what do u think seems to be the problem? and can u tell me why i get such poor gas milage
Oct 21, 2010 at 2:50 PM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 21, 2010 at 4:35 PM
