Thank you for clarification
it look like a short in the system.
There is a Lt blue wire from DIRECTIONAL/HAZARD/HORN SWITCH.
That wire goes into a connector. From the connector. One side goes to the left front directional light.the other side goes into the printed circuit connector.
check the connetion into the printed circuit for corrosion causing short.
make sure it not shorted to ground causing the light to stay on when it should be off.
I'm sending the diagram to your email too, check it out.
Monday, October 26th, 2009 AT 6:31 PM
