1985 Chevy Monte Carlo oil filter
BRUCE BARNETT
Engine Performance problem
1985 Chevy Monte Carlo V8 Automatic
oil filter damaged and not unscrewing. need ideas to remove
May 24, 2010 at 1:55 AM
RENAUDTN
  • 636 POSTS
Drive a long screw driver thru the filter. Now you can use it kind of like a breaker bar to break the filter loose. Don’t let the screw driver stick out too much on the opposite side as you may do some damage when the filter finally turns loose.
Depending on the clearance, you may be able to adapt a breaker bar to a cap wrench and pry the filter loose that way.
Good luck; I had the same problem once and it's frustrating.
May 24, 2010 at 5:18 AM
