1985 Chevy Monte Carlo car want start
ERINSWAY1
Engine Mechanical problem
1985 Chevy Monte Carlo Two Wheel Drive Automatic 65000 miles
Car will not start. I'm getting good fuel and some fuel out of the injectors. The ca r wants to start if fuel is poured into throatof T.B.I. Do you think the pressure regulator could be bad? The injectors and the fuel pump are new.
Mar 14, 2010 at 9:07 AM
VEGASMSTRJ
  • 50 POSTS
that could be the problem or you might have a timing issue or bad spark. all the engine needs to fire is spark and the fuel mixture. we need more details about the engine and what you think is going on.
Mar 17, 2010 at 10:53 AM
ADAM DUTCHOVER
  • 8 POSTS
check the distributer u might need to advance it
Jun 20, 2010 at 2:50 PM
