1981 Chevy Monte Carlo oil leak
MONOLITTO
Engine Mechanical problem
1981 Chevy Monte Carlo Front Wheel Drive Automatic
I have a 81 monte carlo with a 267 motor in it and it has a oil leak on the passanger side. Where could it be coming from??
Sep 1, 2010 at 3:05 PM
HMAC300
  • 48,601 POSTS
it can be teh oil pressure sender under teh distributor but it's on the driver's side, it could be leaking down on the pass side. It could also be leaking at the back of the intake on that side as well. If it is you might be able to put some silicone in it tostop it.
Sep 2, 2010 at 10:39 AM
