1976 Chevy Monte Carlo jerks when i accelerate fast from a
1976 CHEVROLET MONTE CARLO
95,000 MILES • V8 • 2WD • AUTOMATIC
CALIRICAN310
When I stop and accelerate quickly it jerks and goes back to normal. If I slowly accelerat it works fine. I also noticed when I slowly accelerate the fuel economy gauge goes to minimum it never did that before.
Sep 26, 2009 at 9:32 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
this is a guess as you would need the car available to fix it. I would check the distributor plate and vacuum advance for being worn out. Also take out the pick up coil in the dist and vaery carefully look at the wires to it as they used to wear out from being moved. The guage can be bad or a vacuum leaki. Again hard to diagnose over computer this one someone will need to look at..
Nov 4, 2009 at 12:32 PM
