I HAVE CHANGED OUT MASTER CYLINDER AND POWER BOSTER ALONG WITH A CUT LINE. I HAVE BLEED THE BRAKES STARTING AT MASTER CYLINDER AND THEN LT REAR, RT REAR, FRONT LT, FRONT RT (DIRECTION GIVEN FROM FRONT OF CAR). I HAVE FIRM BRAKE UNTIL I START THE CAR. WHAT DO YOU SUGGEST...ALSO HAVE CHECKED THE VACUM GOING INTO THE POWER BOOSTER AND IS WORKING FINE.
Jun 28, 2009 at 2:07 AM
