1975 Chevy Monte Carlo engine not firing
JOE TYNER
  • 1975 CHEVROLET MONTE CARLO
Engine Performance problem
1975 Chevy Monte Carlo V8 Two Wheel Drive Automatic
123,000
Thursday, December 4th, 2008 AT 4:58 PM
Is it cranking over and won't start or just won't crank at all? Please! Explain
Thursday, December 4th, 2008 AT 6:38 PM
JOE TYNER
The engine turns over but it just won't fire or start. Last year I took off my stock exaust manifolds and put on racing headers in order for me to get my new headers on I had to unhook the plug wires and take out the spark plugs. After I put on my new headers I also put in new spark plugs. I did hook up the plug wires in the right firing order. But when tried to crank the engine it would only turn over so I tested it to see if it was firing and it was not. By the way the engine has an HEI distributor.
Thursday, December 4th, 2008 AT 8:07 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, December 4th, 2008 AT 8:15 PM
Related Engine Not Running Content
