1973 Chevy Monte Carlo How to hook up a tachometer
1973 CHEVROLET MONTE CARLO
193,000 MILES • V8 • 2WD • AUTOMATIC
SLOWMOVE59
I changed to a HEI distributor and my old tach,made for point ignition died when i first reved up to 5000 rpm. I think too much voltage on the pickup wire. Now i´ve bought an original Monte Tach from 1973. How can i hook it up without destroying it again?[img:f13fcba882]http://www.2carpros.com/forum/automotive_pictures/333646_1345_1.jpg[/img:f13fcba882]
Mar 19, 2009 at 4:38 AM
DOCFIXIT
  • 18,828 POSTS
Did you have old Tach hooked up to the tach terminal on the HEI?
Mar 19, 2009 at 6:08 AM
SLOWMOVE59
Yes, I did.
Mar 19, 2009 at 8:57 AM
DOCFIXIT
  • 18,828 POSTS
Taht is correct the tach reads each time coil is grounded no power goes from dist to tach that is supplied from cars elect system. Maybe old tach bit the dust
Mar 19, 2009 at 10:14 AM
