1973 Chevy Monte Carlo Alterations for ammeter
SLOWMOVE59
Electrical problem
1973 Chevy Monte Carlo V8 Two Wheel Drive Automatic
Hi, I iwant to installl the optional rally cluster with ammeter. The car has only a Gen. light. What wiring alterations have i to do, for making the ammeter work?[img:e2daceab4f]http://www.2carpros.com/forum/automotive_pictures/333646_1345_2.jpg[/img:e2daceab4f]
Mar 22, 2009 at 11:20 PM
JDL
  • 16,098 POSTS
Hello, nice picture. My info showed the alternator charge wire goes to the bat terminal at the starter solenoid, red wire. Take it loose, run that wire to the positive side of ammeter, run another wire from the negative ammeter terminal back to the same connector at the starter solenoid. Your wiring the ammeter in series on that circuit. Both wires need to be 10 gage or larger. As far as the size wire you use, some info says to use wire rated 10 amps higher than the max output for your alternator.
Mar 23, 2009 at 1:39 AM
SLOWMOVE59
That wouldn´t work. You cannot install such a wire into the stock printed circuit
Mar 23, 2009 at 2:28 AM
JDL
  • 16,098 POSTS
My bad, I was thinking about a single ammeter gage. Maybe some of the others will have a reply. goodluck
Mar 24, 2009 at 1:03 AM
